Braun Reciever RS1 with LV connection?
Harmony
#1 Beitrag von Harmony » 30.11.2014, 00:54
At the moment I get an offering for a Braun RS1 with the possibility to connect it with a LV active speakersystem 8)
Does this type RS1 really exist with the LV connection? I didn't knew it.
Can somebody give some advice.
N.b what is at the moment a fair price for the RS1?
Greetings,
Joop
Braun for your own High-End
Re: Braun Reciever RS1 with LV connection?
#2 Beitrag von andreas schnadt » 30.11.2014, 09:47
Hi Joop,
In the Braun Tax List the price is indicated between 150-250€; I bought mine for 50€. It bad a processor outlet, I dont know of it can be used for the LV.
Yours Andreas
#3 Beitrag von v/d/b » 30.11.2014, 10:29
as far as I know the processor outlet is in front of the volume pot and the tone control.
So it can not be used for the LVs.
Kind regards
#4 Beitrag von andreas schnadt » 30.11.2014, 12:00
Hi Thomas,
you are wrong, the processor output socket is situated in the middle of the backside.
Greetings Andreas
#5 Beitrag von raimund54 » 30.11.2014, 12:11
the RS1 doesn´t have an output for active speakers like LV 720. Of course you can change the internal wiring and use the processor output socket for the LVs.
Usually the processor output is after the preamplifier, but before volume, level and tone control.
Regards,
#6 Beitrag von v/d/b » 30.11.2014, 13:40
raimund54 hat geschrieben:...the processor output is after the preamplifier, but before volume, level and tone control.
That's what I intended to say :wink:
Kind regards
