L420/1 speakers vs. L630 speakers
Harmony
#1 Beitrag von Harmony » 21.07.2014, 21:36
Which of the two speakersets have the best sound?
I have a L630 set but the woofers are broken...and needs a repair.
At the moment I can get L 420/1 speakers for €100,- and they still working...
What can you advice me?
Greetings, Joop
Braun for your own High-End
#2 Beitrag von andreas schnadt » 21.07.2014, 22:04
Hi Joop,
send your 630's toRainer Hebermehl, he is able to turn your bass speakers to new for ließ than 100€, this Would be the better choice!
Good luck Andreas
#3 Beitrag von Rainer Hebermehl » 22.07.2014, 08:34
Ich habe Joop eine PN geschickt.
Danke Andreas
Jens
Administrator
Administrator
#4 Beitrag von Jens » 22.07.2014, 08:49
Hi Joop,
If you like the soundstage of your L630 the L420/1 is probably not a one by one substitution. The L420/1 is a clean sounding but smaller LS by size / driver and a two way speaker system. You might miss that little portion of deep bass the L630 is able to serve you with. Andreas recommendation is therefore the best choice if you like your current speaker.
Best ones from Jens
Don't Panic!
