braun pcs5 and... DL-103?
thebeathunters
#1 Beitrag von thebeathunters » 22.04.2014, 01:22
seems like my old braun flame is coming back... 8)
i'm falling for a grey pcs5 and wonder if a DL103 cart can be adapted to its headshell or have no other choice than stick to the usual shure suspects...
thanks for feedback
"I spent a lot of money on booze, birds and fast cars. The rest I just squandered."
George Best
thebeathunters
#2 Beitrag von thebeathunters » 22.04.2014, 12:02
realized that the pcs5 platter is magnetic, so no MC cart will play :lol:
what good MM cart you'd advise here?
George Best
FLHX
#3 Beitrag von FLHX » 22.04.2014, 15:12
...the usual suspects, Shure M44, Shure M55 or Shure V15, first version with the heavy metal casing, they are all second hand available for reasonable prices and the tone arm was developed for such cartridges, in my opinion they are perfect matches...
Best regards
Michael
#4 Beitrag von Wilhelm » 22.04.2014, 15:31
Hi thebeathunters,
I really don't know what you are talking about. The platter of the PCS5 is not magnetic, it is a zinc-high pressure die-cast.
Regards
thebeathunters
#5 Beitrag von thebeathunters » 22.04.2014, 15:33
:) you mean a dl-103 Mc cart could perform perfectly here?
a friend advised me an AT 150 MLX as possible upgrade for MM
George Best
#6 Beitrag von Wilhelm » 22.04.2014, 15:52
I don't know the dl-103 MC, but a MC cartridge with the right compliance for the tone arm of the PCS5 should work just fine. Worth a test.
Regards
Gründer (inaktiv)
Gründer (inaktiv)
#7 Beitrag von Norbert » 22.04.2014, 17:14
Hello,
the Denon DL-103 cartridge is designed for a heavy or middle-heavy tonearm weight effective mass and has a low compliance. In 1963 first it was a professional broadcast MC cartridge in Japan with a spherical stylus.
You must check it out in your PCS5 - I don't know the tonearm specs.
Best regards
#8 Beitrag von v/d/b » 22.04.2014, 19:32
Moin everybody,
some time ago I read something about using MC cardridges with the PCS 5.
As far as I remember the sub platter was suspected to make problems because of his magnetism.
Never tried it out myself.
Cheers
thebeathunters
#9 Beitrag von thebeathunters » 22.04.2014, 20:10
well, that's what i had read too but wilhelm seemed pretty sure...
George Best
#10 Beitrag von Wilhelm » 22.04.2014, 20:28
Hi thebeathunters,
it is correct that the sub-platter is made out of steel and therefore magnetic, but you talked about the platter which is not. I doubt that the small sub-platter creates a problem in connection with a MC-cartridge. Why don't you check it out and report to all of us?
Regards
thebeathunters
#11 Beitrag von thebeathunters » 22.04.2014, 20:32
edit: ok why not? need to find my pcs5 first :D any help welcome
George Best
#12 Beitrag von Wilhelm » 06.05.2014, 00:01
I just got a new Shure M97xe and I tested the tone arm resonance on the PCS5 with the Shure ERA IV test record. With the damper down, I couldn't detect any vibration at 4,5,6,8,10 and 12 Hz; without the damper there was a strong visible vibration at 6Hz.
Maybe this is valuable information for some of you vinyl fans.
Regards
thebeathunters
Re: braun pcs5 and... DL-103?
#13 Beitrag von thebeathunters » 04.12.2014, 13:04
ok, back on the pcs5 front for good i hope. beautiful white one... to be continued...
George Best
thebeathunters
#14 Beitrag von thebeathunters » 05.10.2015, 22:22
we'll, it took me a whole but here it is at l'astrologie, a very Nice, serviced And upgraded specimen (motor, power cord, DIN to quality RCA, etc)
Will post pics pretty soon. as usually the original headshell seems pretty funny to mess with, in order to fix a new cart. i may ask you guys for help once again... :D
George Best
thebeathunters
#15 Beitrag von thebeathunters » 06.10.2015, 11:38
thebeathunters hat geschrieben:we'll, it took me a whole but here it is at last, a very nice, serviced and upgraded specimen (motor, power cord, DIN to quality RCA, etc)
George Best
thebeathunters
#16 Beitrag von thebeathunters » 13.10.2015, 13:20
sorry for doubling former message
here's a pic of the braun headshell :shock: if someone could help me understand how to disassemble the inner metallic mounting board to install a new cart that would be wonderful!
braun headshell.jpg (87.22 KiB) 14856 mal betrachtet
George Best
