Braun PS-500: How do I reattach this tiny c-clip to the idler wheel?
beatcomber
#1 Beitrag von beatcomber » 15.02.2020, 17:35
I'm desperate. How the heck do I re-attach this tiny c-clip to the idler wheel spindle on my Braun PS-500? It's impossible to push it in place from either the top or side.
Re: Braun PS-500: How do I reattach this tiny c-clip to the idler wheel?
#2 Beitrag von Paparierer » 15.02.2020, 18:09
you need c-ring forceps / pliers like these
beatcomber
#3 Beitrag von beatcomber » 15.02.2020, 18:16
Danke!
beatcomber
#4 Beitrag von beatcomber » 15.02.2020, 23:45
I gave up on the annoying C clip and used a hairpin clip instead.
Problem solved!
