Braun Atelier P1 revision
Trab
#1 Beitrag von Trab » 24.09.2015, 19:25
Hello Braun lovers,
I have my Braun Atelier series from 1980 I think.
The CD player later and today...
I bought a second hand P1 for my records.
My brother is having a look inside because the 45 tempo down't work anymore.
Can anyone help and/or have a technical leaflet?
thanks in advance
Bart
from the Netherlands
Doorn
edit paparierer: I deleted the email address and the phone number - you can be contacted by PN
Re: Braun Atelier P1 revision
#2 Beitrag von Uli » 24.09.2015, 19:34
Look in E-Bay you can find them very cheap there.
Also you can take a P2, P3 or a P4!
Grettings... Uli
#3 Beitrag von Paparierer » 24.09.2015, 20:05
Hi Bart,
you can get the service manual from this site:
http://wegavision.pytalhost.com/Braun/P1s/" onclick="window.open(this.href);return false;
the manual you can find here:
http://www.eserviceinfo.com/downloadsm/ ... un_P1.html" onclick="window.open(this.href);return false;
for the circuit schematics you may have to try auction sites, as Uli recommended.
Hope you'll be able to get the P1 to work again.
Yours, Gereon
P.S. I erased the second thread (i.e. the "clone" :wink: )
