question
vredig
question
#1 Beitrag von vredig » 09.07.2011, 19:12
Can anyone give an indication of the value of this set ??
Kind regards,
Jorrit MaanBild
chrimbu
#2 Beitrag von chrimbu » 09.07.2011, 23:24
800 - 1200 Euro
#3 Beitrag von Friedel » 09.07.2011, 23:28
Die Frage ist aber auch
CD4/1 oder CD4/2?
CC4 /1 oder CC4/2?
PA4/1 oder PA4/2?
Rückklappen, Kabel evtl. sogar Originalverpackung vorhanden?
Fronten ohne Kratzer und nicht abgegrabbelt?
Deckel ohne Kratzer?
Jens
Administrator
Administrator
#4 Beitrag von Jens » 10.07.2011, 19:51
Hi Jorrit,
as Friedel mentioned, condition matters. Further on it is true that the different versions (/1 or /2) are relevant for a relaible price evaluation. If you aren't able to clarify this subject you can manage the identification by your own.
The CD 4 by the way was produced in 3 versions. The /2 Version is the latest and most advanced one equipped by an improved 18 bit D/A converter from Burr Brown. To identify the correct version please dismount the rear barrier and check the connectors.
For CD4/2 this link might help:
http://www.braun-hifi-forum.de/viewtopic.php?t=690
PA 4/2:
This model was equipped by a van to get the heating under control
CC4/2:
If your CC4 is completely original the air grids within the side panels are vertical with the /2 version. The /1 version is coming with horizontal air grids.
Be carefull as the side panel could be substituted over the time. Following message from the CC4 if controlled by an RC1 remote control will appear if this is an /2 version:
If you push the speaker button on the RC1 (Audio setting) the CC4 will respond with a SP 1/2 +3/4 message in the LCD.
Needless to say the /2 are more expensive versions.
Jens
Don't Panic!
