Hello
I use following atelier units: R4/1, CD 2/3, P1 with ORTOFON OM20, and keep in depo A1 and T1.
I use VANDESRSTEEN 1B and BRAUN L710 speakers - I switch them from time to time.
Here are some questions:
Should I get P3 or P4 turntable (I dont need remote control for turntable). Would the sound improve much with P3 or P4?
R4/1 is heating up a lot. I could use A1 amp as power amp. Would this reduce the heating problem in R4. Any toughts?
Thanks for any advice.
Regards Marko
BRAUN atelier turntables etc
svoperokram
- Neuling
svoperokram
- Neuling
Re: BRAUN atelier turntables etc
Hello
Thanks for reply.
I could use some help doing it. I will take it to the shop to be done, but some instructions would be very helpful.
Regards Marko
Thanks for reply.
Regards Marko
The step-down part you can find in this Thread http://www.braun-hifi-forum.de/viewtopic.php?f=3&t=9083
